Results 1 to 7 of 7
Thread: Unique small rear calipers for ST?
Hybrid View
    Senior Member matteo68's Avatar
    Jul 2021
    Bicester, UK
    I’ve recently been advised by a reliable source that the ‘70-‘71 2.3 ST and the 21 ‘72 2.5 STs may have been fitted with a unique and extremely rare small S alu caliper on the rear axle but I have no photos of this to confirm.
    Is anyone else aware of this part at all and if so, can you share any info please, especially some photos?
    Thanks!
    ESR #4098
    ‘72 T Coupe (donor car for M491 2.5 SR)
    '72 S Coupe (2-owner tangerine unicorn)
    Looking for 915/00 gearbox #7120023
    From Instagram:
    CarPoint
    COM11.1.127
    Rear 911R-911ST-914/6
    For 20mm Vented Discs
    901.352.050.13
    Aluminum Brake Set
    I can't pull the CarPoint #. Are those repro? Just curious as I went a different route for brakes.
    Oct 2008
    Burford, ON, Canada
    Interesting, and not ATE like the originals. Not on their website, and part # is for something else??
    The original rear ST ones are aluminium, identical to the 914/6 GT Caliper. Front Calipers are sometimes 908 Magnesium. My car came with two Magnesium in the front and unfortunately only one aluminum for the back. The CarPoint ones are nice repros.
    Dec 2013
    France
    It would be interesting to know the distance between the fixings of this rear calipers.
    I think the distance is not the same on 911 SWB rear trailing arms and ST (LWB)
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by MPST View Post
    Please explain further. The 914/6 GT Calipers are cast iron and spaced for vented rotors: example
