Results 1 to 10 of 11
Thread: Alu 901/13 engine to S specs
    Feb 2012
    Netherlands, Leiden
    Hi all,
    I have an aluminium 1968 911 engine, type 901/13. Originally these engines were used in combination with the sportomatic gearbox.
    If the engine needs a rebuild, I would like to change it to S specs from 1967-68. What do you guys think that need to be changed?
    • Pistons & Cylinders
    • R901.104.305.02 911S heads for the correct size valves
    • A counter weighed crankshaft
    • S rods
    • 002 yellow tag S distributor
    • Changed Weber IDA or Weber IDS carbs
    Would these be the most important changes to the engine? Or am I missing things :-)
    Don’t forget camshafts.
    Feb 2012
    Netherlands, Leiden
    Quote Originally Posted by Rick Cabell View Post
    Agreed Rick, the correct cams, anything else?
    901/13 is a T engine , so you might have the large ports on the heads , seem to remember they are similar to 68S ,
    Balanced Crank might cost a bit , and B&Ps
    I think that’s it. You will spend a ton buying all these parts and finding them. 67/68S only.
    Feb 2012
    Netherlands, Leiden
    The 002 yellow tag is in the engine already, set of heads was 1200€. The CW crank will be expensive indeed
    Cheap on the heads, I paid $2500 10 years ago for the last set I bought.
    Feb 2012
    Netherlands, Leiden
    Yes I agree, it is a good price!
    You might want to look at your engine before you buy a crank, I seem to think they were all counter weighted back then.
    Feb 2012
    Netherlands, Leiden
    Yes that is true, hope that there is a CW crank inside that is usable.
