Results 1 to 3 of 3
Thread: Turbo tie rod on 1965 with steering damper ?
    Feb 2013
    bordeaux
    Hi ,
    I would like to know if anyone has ever fitted turbo tie rods on an SWB with a steering damper?
    It seems to me that the protective rubbers (those from elephant racing for example) are not made to fit the right side of the steering damper support
    Thank you for your answers
    Vincent
    Have them on my 67 without damper but they had to be modified.
    Apr 2011
    N.Calif., south of SF
    As a side note, when I replaced my 66 911 steering damper I found a Koni. Had no idea. It seems to have worked quite well.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
