Thread: 71 shift rod replacement
    Aug 2021
    Surrey B.C.
    Hello all,
    I have been asked to help finish a long term project. 71 T-- the shift rod is to short. Looks like someone had a 915 box but now has the 911/901 box. Is it possible to replace the rod with the drive train installed?
    Just looking at it, if I remove the trans mount and lift the trans as high as it will go, it might work????
    Thanks Jake
    mbr#4161
    69 911t
    72 2002tii
    May 2014
    South East USA
    My first thought.
    The original shift rod is put in thru the front, between the seats.
    I’ve never put one in from the rear.
    A 356 is done that way, don't know about 911, never tried it, but sure doesn't look like there's room to do that.
    Aug 2021
    Surrey B.C.
    answer Yes. In addition to the above, remove the rubber boot around the shifter in put shaft. It will need a bit of coaxing and twisting. Now to find a used one and install.
    Jake
    mbr#4161
    69 911t
    72 2002tii
    Oct 2010
    Southern Ca.
    I tried without removing the engine - trans , I finally gave-up and removed the engine - trans . I would say it's not possible without bending something .
