Results 1 to 3 of 3
Thread: Gas Tank Clear Vent Hose Info
    Looking for specifications on gas tank air vent hoses. Need a purchase source and ID/OD sizes. I believe one is 16mm x 22mm. Thank you
    Senior Member 68S_SK2's Avatar
    Mar 2006
    Munich, Germany
    What I can confirm is for 1968 SWB:
    7x14mm from the tank to golden tube
    4x7mm from the brake fluid reservoir into the little side inlet of the golden tube
    LWB is different, I have no measurements for it.
    I hope it helps.
    BR
    Claudius
    Thank you Claudius
