Thread: Service Offer: VDO Kienzle Clock Repair
    Mar 2004
    Castro Valley, Ca.
    for anyone interested I will service this or a similar clock for $50 + return postage. (as long as it *doesn't* indicate 'quartz' on the dial)
    if you're feeling adventurous and are willing to invest in a few tools you can probably tackle this chore with the help of this article;
    https://www.pelicanparts.com/techart...ock_repair.htm
    1940 Mercury town sedan
    Senior Member The chief's Avatar
    Jun 2016
    Napa, CA
    Hi, my '67 VDO clock finally quit on me. Can ya fix it? I PM'd you too. Thanks
    Jun 2016
    Napa, CA
    Jerry typ901 serviced my clock and now it works great! 50 bucks well spent to have my original clock functioning again
    Thanks Jerry!
    Member McOtto's Avatar
    Apr 2023
    Denver, CO
    I know this is an old thread, and I think my post count is too low to PM. However, I am hoping typ901 might be willing to take a look at the electro-mechanical Kienzle clock in my ‘72 911. Thank you!
    Apr 2023
    Denver, CO
    After fiddling with the clock, I was able to identify the problem - as is often the case, it was me.
    I was not disengaging the time adjustment button by pulling it out after resetting the time. I guess not doing so was causing additional drag on the clock works. It would work for a while and then stop. Tap the face a bit, it would start working again.
    After correcting the aforementioned operator error and a slight + rotation of the fast/slow adjustment, the clock has been keeping very accurate time for the last couple of days.
    Mar 2024
    Holmdel, NJ
    Looking to see if you still repair clocks
    Quote Originally Posted by typ901 View Post
    I have a kienzle / vdo that needs some work - it seems to work intermittently - but had sat in a barn car forever....so prob needs reconditioning.
    Any chance Typ901 you can help? I just joined so cannot message you.
