Thread: Key set on a SWB
    Key set on a SWB
    Hi everyone,
    I would like to know, when the SWB MY68 were sold new, if they came with only one key for both doors and ignition or two different ones for each. I don’t know if the glove box was included but from the lock I have it does not look the same key…
    Thanks in advance for any help.
    Oct 2008
    Burford, ON, Canada
    The 1968 had 2 keys at a minimum; the glove box key was separate from the others. The ignition could be FL or K type depending on the presence of a steering column lock.
    Thank you very much!
