Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: VHT high temp paint
  1. #11
    Ed, have you seen how it holds up over time?
  2. #12
    Anybody look at Cerakote ceramic paint good for hi heat They have lots of colors
    Thanks, Rick
  3. #13
    Cerakote would probably work good, but I was looking for something I could do myself. Nobody around me does it so it would call for shipping, packing, ect.
  4. #14
    Lightbulb
    I'm trying Cerakote as we speak (meaning done in a few weeks)
    We settled on this color:
    GLACIER FORGE - C-8200
    Will report back with pics...
    cm
    I have been using the Cerakote on a few things, some headers, engine aluminum parts . It is easier than spraying paint or powder coating The only thing that you need is a gun with a .80 tip I picked up one from Amazon for 40 bucks They do want to have the surfaces sand blasted but I have done bits that have been vapor blasted and it stays on All the stuff that I have tried has been their air cured stuff. I tried the stuff that requires a baking and has a catalyst but I wasnt able to bake it long and hot enough at the time so it did not come out well
    Thanks, Rick
  6. #16
    Is cerakote available in the flat gray like factory exhaust? Sounds like it is doable at home.
  7. #17
    Here are the Cerakote Greys Rick:
    https://www.cerakote.com/shop/cerako...olor=cera_grey
    cm
    I use cold galvanizing compound on exhaust parts. LPS brand is my favorite. Easy to use spray cans, flat gray color, no curing quick dry, best over a sandblasted surface. It will burn off pipes by the exhaust ports a bit but holds up well for the rest of the system.
  9. #19
    Interesting product. I went to the website and it does not say anything about high heat usage.
  10. #20
    Aug 2020
    Shawnee, OK
    I used the CRC cold galvanizing after wire brushing the exterior. One can did the muffler, looks good to me and still nice after a year.
    Steve
