Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: VHT high temp paint
    VHT high temp paint
    I have used VHT high temp paint on exhaust for years. In the past year I have has trouble with cans clogging before 10% is used. The parent company Sherwin Williams has been great, refunding my purchase price twice.
    Well I just spoke with customer service, which is super, and the SP 104 flat gray is discontinued.
    Does anyone know of a proven gray exhaust paint? I know Stoddard has a paint, but is is double in price and only about half of can size.
    Rick, if I am not mistaken, Stoddard no longer carries their exhaust spray paint. I did some investigation and the paint I ended up using for the exhaust system on my early 911 is the one recommended and used by John Willhoit: Thurmalox High Temperature Dark Gray Exhaust Paint. He sells the paint.
    Interesting, I just went to the website for the manufacturer and did not see grey, I’ll look again.
    Might also try Dupli-Color and their line of engine paints. I’ve also had the same clogging issue with the VHT paints and am not terribly impressed. Dupli-Color goes on really nicely.
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    there seem to be some rest stock here in germany
    https://www.ktsamericanparts.de/mobi...rte&pid=749951
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Rick and all, thread fits better over here ...
    It must be old stock Haul. The gray is the only color discontinued. Would not dare buy it again as all I have bought plug. On this style of can to remove the nozzle and try to clean it is not possible.
    I’ll order some Thurmalox and Duplicolor and try it. Didn’t know duplicolor made high heat.
    Eastwood has this high temperature paint in factory gray. I have not tried it.
    https://www.eastwood.com/ew-factory-...82489625937123
    911 S Registry # 1054
    1970 911 E Coupe Signal Orange (#1414)
    1979 BMW 320i
    2001 Boxster S
    2003 Audi Allroad 2.7T Tiptronic
    2014 Jetta Sportwagon TDI DSG ( sold back to Volkswagen)
    2015 Allroad 2.0 TFSI
    Probably not as good as the VHT paint, but the Wurth zinc rich weld thru primer is a decent color.
