Thread: twin plug dizzy
    Nov 2003
    Santa Monica CA
    twin plug dizzy
    Which twin plug dizzy to buy? Patrick Motorsports issue, JB racing issue or what? Thanks Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Feb 2011
    Northern VA
    I believe Aaron Burnham (in Camarillo) is back in production with his very fine Bosch based twin plug distributors. Henry and supertec produced/produces a very similar version. Maybe done by Aaron? Two sets of bearings. Uses the MM cap. Points. These are very good equipment. No shot against the others. Jb is good too. Seen but not personally used.
    Apr 2004
    35,000 ft
    I have a couple of spares. Currently stored with my car in Orange County. If you’d like to try and buy one. They were both installed in my 2.7 which is a 7R case 72 motor.
    One is a Burnham distributor that I ran for 40,000 miles and it was great, I sent it to aaron for a full rebuild and review. And then my motor came out for a rebuild. Engine builder wanted to go in a different direction.
    I also have a mittel motor distributor that was designed to look exactly like the Magneti Marelli distributors but feature modern electronics complete with 123 electronics with Bluetooth tuning capability. Which is essentially brand new.
    Reach out to me by email and I’ll fill you in on details of both.
    Nov 2003
    Santa Monica CA
    Hi blucille this project is going into a 67 aluminum case, so I need a 27MM shaft size to fit in the case. any of yours will fit? I can PM you if you like.
    Aug 2013
    Westlake Village, Ca.
    Quote Originally Posted by geneulm View Post
    I don’t believe that Aaron is in this business any longer
    Scott
    303581
    I chose the JBR distributor.
