Results 1 to 5 of 5
Thread: SWB turn and emergency relay wiring help needed
    Well, just before selling my 67S I was checking lighting and discovered the emergency blinkers didn't work. So, one thing led to another and now the turn signals quit. I bench checked relays and blinkers and replaced faulty items and although I labeled my wires, the bloody thing is still troubling me.
    I attach the following drawing to show how I have connected everything. I am pretty sure it is correct but something is just not kosher. Please help!
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    My hard won advice: make sure you don't have any LED bulbs in the system.
    All incandescent.
    Paul Abbott
    Early S Member #18
    530.520.5816
    Hi Paul,
    Start simple. Have you checked ground at the bulbs? I was having terrible problems with mine (66). Went to the light assembly put a simple test light on the feed wire and ground and the test light was blinking just like it should. I cleaned (file and sand paper) every socket and connection on the light housing reassemble and everything worked. The test light is your friend.
    Electrical was by far the most frustrating part of the restoration process. Best of luck
    Joe D
    1966 911 #302694
    Good advice Joe.
    Lights were 100% and now blink fast. A member in Germany provided a link that helped:
    https://www.early911sregistry.org/fo...elays-Analyzed
    Paul Abbott
    Early S Member #18
    530.520.5816
