I replaced with this -https://patrickmotorsports.com/collections/battery-mount-packages/products/elebat911dbkpms
Marc
Early 911S Registry #4145
1970 911S Coupe Sepia Brown
Houston, TX
Any guidance on which battery charger works best with the Sonnenschein Gel Battery ?
My Moll's have bitten the dust after 8 years so have ordered a pair from Lauderdale Battery today...
My existing battery chargers are listed as for acid based batteries only...
Nick D - Run Flat
1973 RHD 911 Carrera RS #0358 - Fun Car
2016 Cayenne Diesel - Tow Car
2017 Macan S - Better Half's Car
1955 356 Speedster SOLD
1976 911 2.7 SOLD
2006 Cayman S SOLD
2006 Cayenne S SOLD
2008 Carrera S F77 SOLD
2011 Cayenne S TOTALLED (T-Boned but kept us safe)
2015 Macan S SOLD
2015 GT3 - Track Car
2016 Cayenne SOLD
2016 Cayenne GTS TOTALLED (Bloody big deer)
Still looking for 1st Edition Carrera RS book #358.
Life is way too short to drive boring cars.
I've used this one for years on mine.
I use battery 'maintainers' as opposed to straight chargers. The maintainer senses the battery charge and will regulate on/ off as required to keep the battery charged. You turn it on and leave it on to do its thing. There are many available but I have bought mine from Griots. It does have a gel type setting. For my daily driven car I don't need to use anything.
I use this on my Sonnenschein’s when needed: https://www.batterytender.com/3amp-selectable-voltage. Works great and detects battery type.
My 10-year-old Sonnenschein still tests good, but probably reaching the end of its life. Before that happens unexpectedly, like you nickd, I just ordered two new batteries from Susie at Lauderdale.
On battery tenders, I have been using this Schumacher unit with success. Inexpensive and readily available, the tech rep at Schumacher confirmed it is appropriate for use with the Sonnenschein battery. https://www.amazon.com/Schumacher-SP...cd67b74bc&th=1
1972 911T Targa
1985 911 Carrera (with circa 1988 RUF 3.4L 260 hp DIN Engine Kit)
Thanks folks for your responses - very helpful - I've acquired 1 of these recently -- https://www.batterytender.com/plus. It's a maintainer also. I do have an old version of the same but I suspect it's not gel compatible, so likely source https://www.batterytender.com/3amp-selectable-voltage.
Nick D - Run Flat
1976 911 2.7 SOLD
2006 Cayman S SOLD
2006 Cayenne S SOLD
2015 Macan S SOLD
2016 Cayenne SOLD
