Results 1 to 10 of 17
Thread: New Battery
    Member kent olsen's Avatar
    Sep 2010
    McMinnville, Ore
    New Battery
    This last week I've experienced a no start when I run out in the garage to run into town in the Porsche. Starts up ok after a short recharge with my charger, but then the next day, no start. Pulled the battery, which I had previously moved to my smugglers box and lo and behold the date was 03/14!!! Wow 9 years, guess I got my moneys worth out of it. So will pick up a new one today.
    Kent Olsen
    McMinnville, OR
    72 911 upgraded 3.0L
    RGRUPPE # 104
    Apr 2003
    Portland, OR
    Only 14 years. Send it to the manufacturer for warranty replacement!!!!!
    Harry
    Member #789
    2009 MB C300
    Dec 2010
    Southold, NY
    Recently replaced mine. October, 2002 to April, 2023 was a good run by any standard (21 years), but my Sears Die Hard Group 58 just wouldn't take a charge anymore. Reluctantly went to NAPA for a replacement. Purchased a Defender Group 58 (NAPA Part No. 7558) and installed same. BTW, the Die Hard cost $49.99 in 2002, the Defender cost $150.00 in 2023. I wonder how long it will last.
    I need to replace both batteries in my 72 911 T. I was searching last night for AGM batteries, thinking about potential leakage and rust associated with acid batteries. Does anyone have a recommendation as to whether AGM is the right move and, if so, any that will fit the early 911 cars with dual batteries?
    May 2006
    CT
    Many of us use the SONNENSCHEIN BATTERIES available from Lauderdale battery in FL. Expensive but long lasting when properly maintained.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Thanks Tom. BTW, you might notice I posted the need for a space tube 901 110 236 00 in the parts needed section this morning. I saw on a post yesterday that you might have some available. If that's true, could you PM with with price? I tried to PM you but not able for some reason.
    Member RW7810's Avatar
    Dec 2003
    Van, TX
    Tom, which model of this battery do you recommend for an early 911T?
    Robert Williams
    911T
    Member #1611
    Sonnenchein for sure, best option.
    May 2006
    CT
    I have been using the Sonnenschein A512/40A battery. I buy them from Lauderdale Battery in FL.
    Lauderdale Battery
    2415 SW 3rd Ave, Fort Lauderdale, 33315, FL
    Phone: (954) 525-5557
    Tom Butler
    1973 RSR Clone
    1970 911E
    Sep 2012
    Philadelphia, PA
    My Sonnenschein just died after 5 years, not as long as I expected. It's been on the trickle charger for the last 2 weeks, which showed it was charged, but it wouldn't start. I am unhappy; I may hit up the AAA for my free battery (premiere membership).
    Serge
    Early S Registry #2457
