Results 1 to 8 of 8
Thread: New case bolts vs used ?
    Guys
    For 71 Mag case …should I buy new case bolts ($$) vs reuse of originals.
    Dont want to spend unnecessarily but if recommended…will do !
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    I will defer to the experts but FWIW, I’ve rebuilt 3 mag case (70-71) engines and I’ve reused the case through bolts on all 3. I did have Ollie’s machine the halves and machine back to standard but otherwise I just reused the bolts.
    Stretch
    Registry # 3063
    Nov 2003
    Santa Monica CA
    my engine builder I assume used my original thru bolts. there was no mention of getting new ones. We did use new head stud bolts and I think that is standard practice for my tech
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Dec 2010
    Wilmington, DE
    Used is fine. They don’t generally go bad. Not much heat or stress like head or exhaust studs.
    A part isn't purchased until paid.
    The 9 Store LLC.
    I have read they do reuse…but a post by recognized builder states that the later version uses fine threads vs the coarse threads of earlier … torque more accurate
    Does anyone have a great set for reuse?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    I always reuse the thru bolts, choosing not to re-plate them.
    Dec 2009
    Copenhagen, Denmark
    71Gold. Are you getting your case machined true? I highly recommend you do.
    James Hurst #1638
    R Gruppe #514
    Yes Ollies did everything imaginable, we at the assembly stage..
    Also question regarding setts I have seen ….most are black oxide but some are shiny metal and not refinished ?
    What’s experience with finish difference?
    Are the fine thread from later cases and and fit 71 case ?
    Thanks again
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
