Results 1 to 7 of 7
Thread: Spinning Shifter
    Dec 2013
    Connecticut/Florida
    Spinning Shifter
    For some reason my gear shifter shaft (not the knob) spins which makes it a pain to change gears. Tried researching and it seems that the ball assembly can loosen from the shift lever. Pelican says you can just epoxy the two parts back together? Anyone else seen this?
    1971 911S Coupe - Gemini Blue
    Aug 2017
    el sobrante ca.
    il bet you chromed the shifter
    you have sheered the pin
    Dec 2013
    Connecticut/Florida
    Yes I did…you can see it’s still wrapped here…
    The shifters were epoxied into the base for crash breakaway protection. U can re-epoxy it or I brazed mine.
    Aug 2017
    el sobrante ca.
    i was referring to a 1968 shifter
    looks like yours may be different per gled49
    Dec 2013
    Connecticut/Florida
    Thanks guys
    Dec 2013
    Connecticut/Florida
    Thats what it was....needed epoxy...
