Thread: WTB: air filter clips ...
    Mar 2004
    Castro Valley, Ca.
    ... in the style pictured please.
    *** update: found some, thanks! need 2 more please ***
    1940 Mercury town sedan
    Feb 2012
    Netherlands, Leiden
    I might have some, can you measure the length you need?
    I need some for Solex 40PI if you have them to swap? Your pic looks like they are for a Weber Air Cleaner?
    Mar 2004
    Castro Valley, Ca.
    hello Jesse;
    if I'm measuring this correctly the clip is 30mm long. sorry, no luck on Solex type. the only spares I have there would be venturi / choke.
    thanks for offering.
    jerry
    Feb 2012
    Netherlands, Leiden
    Hé Jerry,
    If I measure the spring plate (is that the word for it) they seem to be longer:
    Mar 2004
    Castro Valley, Ca.
    hi Jesse;
    measuring with the same method I get 33mm. the slight difference is probably owing to curvature of the "plate".
    I'm sure the shorter of the pair you posted is correct.
    Feb 2012
    Netherlands, Leiden
    Ok! Send me a PM if you want to buy one of them!
    Jesse
    Mar 2004
    Castro Valley, Ca.
    found some, thanks! need 3 more please.
    Mar 2004
    Castro Valley, Ca.
    two more please.
