Results 1 to 8 of 8
Thread: Coco Mats
    Coco Mats
    I know that coco mats were available for the 356s and the early 911s. Does anyone have a photo of some OEM coco mats as installed in a 1965 or 1966 911 that they can post? I have a set on order and I am trying to decide whether to make the set without the rubber heel guard for a cleaner look. Thanks.
    Lightbulb
    prs356,
    This thread search might help:
    https://www.early911sregistry.org/fo...archid=4536127
    Thanks Chuck. Unfortunately, the link doesn't work.
    Sorry, it's working for me... Maybe you're having smartphone interlink blues ?
    Maybe try it on your computer ?
    Just a though...
    Or ... Go up to our 'advanced search' button and type in Coco Mats
    Good luck,
    Chuck
    Sep 2012
    Colorado
    That link does not work on my PC either. IMO Cocomats are fabulous. For practicality, I'd recommend the version with the rubber heel pad under the pedal cluster. Nobody will ever fault you for that.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
    Whoa ... The link stopped working for me as well... sorry
    Try this:
    https://www.early911sregistry.org/fo...archid=4536311
    If this doesn't work I'll give up... And just type in Coco Mats in our 'Advanced Search'
    cm
    Thanks Chuck. Advanced search did the trick.
    Aug 2006
    Chicago area
    I have a set of Porsche OEM coco mats on the 73.5. It has a rubber heel pad with "Porsche" embossed on it. FYI
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
