Results 1 to 9 of 9
Thread: Fuel Hose Cap (original Cohnen Stamp) 901 108 219 00
    For sale: An extremely accurate reproduction of the Cohnen fuel hose caps found on 356, 912, and 911 fuel systems. Used on Weber banjos, Bendix and Hard fuel pumps, and various areas on the fuel hard lines.
    Available in clear or yellow chromate.
    $12 per cap, shipping $7 for US or ROW $10.
    Please send Pay-Pal to brad@911rennen.com
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Hey Brad,
    Look great! I need 20 for solex sets.
    Feb 2012
    Netherlands, Leiden
    These look great! But aren’t the solex 40PI longer ones? See picture:
    The slip ferrule in your picture is for the smaller diameter hose and there are about 15 of those. At the fuel pump and at the hard fuel line at the body you need three of this larger slip ferrule. I think Webers use 4 of these.
    Is there a source for the Solex ones? I need three that my plater was kind enought to loose
    Feb 2012
    Netherlands, Leiden
    I don’t think there is. But I think I have 3 original spares for you.
    Feb 2012
    Netherlands, Leiden
    Quote Originally Posted by rcnagel View Post
    Ah thanks for your explanation. I didn’t know that. The one I showed came of the fuel line between the carbs:
    Jan 2019
    These look very nice! But I'm curious how they get assembled? When the hoses are dried out, there's not a lot of effort to disassemble. But with fresh hoses, it's impossible to just press them together. Is there a tool or technique? Thanks
    Thanks Casey! I hope you like the caps!
    Mark, I have used the caps with 7mmID and 7.5mmID fuel hose and they go together without any blood or swearing. Just a miniscule amount of Dow 111 helps with the assembly too. I place the cap on the end of the hose and then insert the banjo or tube. You can also slide the cap on the tube and then the hose then snug the cap down over the hose. The cap has a tiny sight hole so you can check that the hose / cap are fully seated together.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
