Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Thread: What’s this hole for 1973 RS
  1. #31
    Sep 2006
    San Francisco
    My RS has the black box (no charcoal). IIRC, the exit vent line from it (the smaller tubing) goes to a Y-connector that has a drain tube from the brake reservoir overflow port. The combined outlet of that Y connection is a drain tube that goes through a clip in the cardboard fuse cover, and then through a grommet in an opening in the front panel. That little square opening in the cardboard cover is where the clip mounts.
    Jeff Jensen
  2. #32
    Jun 2012
    London, Ontario, Canada
    I have the hose clip that mounts on the cardboard if anyone needs it. Just pay the postage. I bought it in error before I learned it was only for ROW cars.
    The black tank under the cowl has a tendency to crack over time and thus vent fumes. So finding a good used one is likely impossible. There are new ones made. You also need a square section giant o-ring to mount it under the cowl. NLA, but you can get the essentially correct one from McMaster-Carr. I have a few posts on this somewhere, including dimension, maybe in my build thread. The modern replacements (part number 901.201.618.22) are all round, which is wrong.
    Ravi
    EDIT: Here is the info. https://www.early911sregistry.org/fo...re+o-ring+tank
    Early 911S Registry # 2395
  3. #33
    The Netherlands
    I think I have a 2.73 dated 85L tank currently in my RS. I am considering to put the original repaired 5.73 dated tank back in. Let's talk.
    Cees
  4. #34
    I thought that the plastic tanks aged out. Most plastics don't last 50 years, even less when in contact with gasoline.
