Results 1 to 10 of 10
Thread: Need advice on these Hella 128 fog lights
    Hello
    I have the opportunity to acquire what appears to be original Hella 128 fog lights coming from a 1966 911.
    One of the outer bezel is broken, do you think it would be possible to weld it and chrom it again ?
    Any other comments welcome regarding the specs of these fog lights.
    Many thanks in advance
    François
Size:  50.7 KBName:  C881E0E4-78A9-41EC-8F4F-EAE1AE4E185A.jpg
Size:  51.5 KBName:  BD8177FF-0400-4E1E-A9A1-DB1BC1EDFFA5.jpg
Size:  68.8 KBName:  BE449B9B-1F81-462B-9E3E-2C8FC4265BCF.jpg
Size:  41.9 KBName:  E82BD658-E2A4-45E6-89CC-8279CFF7E3A5.jpg
Size:  48.5 KBName:  12CC05BE-3E2C-44AA-A81A-1278BBD3AF4B.jpg
    Francois might be easier to find an used bezel.
    BTW this trim ring is 67/68?
    On the earlier lights there was a small watering hole in the case and not bezel?
    Richard
    Thank you Richard
    You are right, finding a used bezel would be easier, but this must be hard to find.
    I spent hours reading thread on Hella 128 and this is still confusing for me to understand its evolution.
    Indeed, no drain water triangle in the housing, no rivet at the back, so probably not a 65/66 model…
    Do you think these are repro ?
    Merci Philippe !
    Already read the threads.
    Impressive work on your car, great to see all your notes
    Senior Member 300090's Avatar
    Sep 2019
    FRANCE
    Quote Originally Posted by François View Post
    Merci Philippe !
    Merci François,
    Finding the correct parts for our cars is a real challenge.
    Thank you members for the help you give us in this permanent quest.
    Philippe
    Ivan fuller wrote an informative thread about 128 starting in 57?
    Have you seen that? What year is your car?
    Richard
    Yes I did
    My car is a March 1966 912
    I have these which seem to be pretty close to yours? Top picture shows the one on the left is a little different with a rivet in the center. I bought these 20 years ago for my 356 but never used them. Do you have any idea what vintage they might be?
    Craig Williams
    Eugene,OR
    Member #1070
    1972 911E Targa Puck
    Sorry Craig, can not help you to détermine vintage. Calling experts :-)
