Thread: non start 72 911T stock ignition
    Jun 2011
    Bellingham, WA
    My battery died, had a jump, car ran for about 20 minutes and ied again. tried another jump and won't start
    Today I hooked up a timing light and there is no flashing.
    How do I test the CD module and what else should I test such as coil or rotor
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Tom
    I would hazard a guess that your batteries/ battery need replacing.
    Mark
    Jun 2011
    Bellingham, WA
    oops, I thought I mentioned that I replaced the battery, still no start
    Just fuel or spark.
    Pull the lead off a plug put it on a spare plug and hold it against ground to see if it sparks.
    I think Ed does it a different way but for me this is simpler. If you get spark you know where to go next.
    You might want to check that the sock filter at the tank is not clogged.
    Apr 2011
    N.Calif., south of SF
    check the points?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Jun 2011
    Bellingham, WA
    I have no squeal fron the CD unit and zero volts at the coil. the 12 v comes fromthe CD unit. I do have 12v at fuse 8, which feeds the CD
