Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 119
Thread: Why I like the 72 911 the most?
    Jul 2006
    Corvallis, OR
    So, I get asked this question quite a bit so I thought I'd just list the reasons why here. I'm not trying to start a debate just listing my reasons. I know you all have your reasons why you like the other years maybe even better. So, here it goes.
    1. The oil tank location. This is pretty obvious as it's the most unique feature for the 72. Better weight distribution to move the tank forward. The fill location through the right rear quarter panel is a cool feature.
    2. The new for 72 S front bumper. Looks great and improved high speed down force.
    3. Silver trim lenses and chrome horn grills. Even though I like the black engine lid grill and letters on the lid I that the fact that the 72 retained the silver trim lenses and horn grills.
    4. 915 transmission. I like a well set up 915 box. It can handle more HP and torque. I'm more used to the shift pattern.
    5. 2.4L engine. More HP and torque. Very easy to upgrade to a 2.7RS engine.
    6.Interior changes. I like the German vinyl on the dash trim and door panels. In 72 they went away from the basket weave.
    7. Easy upgrade to rear aluminum trailing arms. 74-77 aluminum trailing arms are a bolt on upgrade.
    8. Some of the very first early prototype 73RS and RSR's were built on a 72 tub.
    9. The factory built 72ST's. Just the ultimate 911 to me.
    So, anyway that's some of the reasons it's my favorite year.
    72S, 72T now ST
    Mar 2017
    Orange County, CA & Tucson, AZ
    I also like the '72 - but I am biased My '72 is an early one -- July '71, so it has some carryovers from the '71 model year - including basket weave. Wonder when that changed over?
    Bill
    Early 911S Registry Member #4087
    Instagram: @myflat6
    '72T hotrod 210 0228
    '82SC Targa
    '97C4S (sold - and regretting it)
    Jul 2006
    Corvallis, OR
    I had 9112300023 also manufactured in July. No basket weave. What's your vin#?
    72S, 72T now ST
    Mar 2017
    Quote Originally Posted by Longballa View Post
    My VIN is 0228. My car also has the earlier Engine Bay Relay Panel Cover and Door Check Strap Pins. It also had the earlier style crossover oil line (from motor to reservoir) that was all rubber and ran over the top of the motor/transaxle -- not the type with the solid metal section that runs under the motor. When I restored my car, parts were date coded 4/71-7/71. My car is a T if that makes any difference.
    Bill
    Instagram: @myflat6
    '82SC Targa
    Following
    Instagram
    Twitter
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    to add to Longballa's list
    10. Flag Mirror.
    Please excuse the horn grill fitment,, I removed the Thru Grill Hella 118 lights due to the amount of gravel road driving I do.
    Gravel Dust n Muck
    Mark
    Sep 2018
    Netherlands
    Interesting... just as I had come to the conclusion that the more revvy 2.2S was the one to have. Depends on whether you want to upgrade to 2.7 RS spec I guess.
    1970 2.2S Elfenbeinweiss
    2002 996 TT Midnight Blue
    Member #3833
    Oil door is cool, but #4 is key
    Not having to deal with that ridiculous dogleg shift pattern is main advantage
    Member kent olsen's Avatar
    Sep 2010
    McMinnville, Ore
    Hi Scott
    Well you've seen my 72. Had it for 24 years, 249,000 great miles. I too have the aluminum trailing arms but when I looked into building up the magnezium engine I chickened out and found a 3.0L. That engine has been in the car for 10 years. Built it with the help of J&B Racing when I lived in Florida. Twin plugged and bullet proof.
    Kent Olsen
    McMinnville, OR
    72 911 upgraded 3.0L
    RGRUPPE # 104
    Aug 2009
    SF Bay Area
    I've noticed thru the years that 72s are prone to rust under the headlight buckets, even in "California" cars. 71 and earlier cars don't do that. I'm guessing that the factory changed the way under seal was applied in that year. Your thoughts, Scott? By the way, I'm using a pretty large sample set.
    Jim
