Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Battery cable routing
    Apr 2011
    N.Calif., south of SF
    I spied something I had wondered about ..... the clip that holds the windshield washer tubing to the fuse area cover! What or where does one find that clip?!
    Name:  911 battery & fuse box cover.jpg
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    That is not the tubing for the windshield washer fluid , but the hose for the fuel vent and the brake fluid resevoir vent - overflow for '69 US cars and '69 and later European cars .
    Apr 2011
    Richy, is there a date range for this vent or just the '69 cars?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Steve, u should install the rubber insulation blocks on your positive cable ends of the batteries, available from Porsche. Pix shows one installed and one upside down so u can see the profile.
    I can attest to the problem that may be caused if they do not exist or are not put on properly and fall off (as in my case).
    Lucky to not lose the whole car to fire!!
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Quote Originally Posted by Haasman View Post
    Was available at Sierra but last time I saw it said Out of stock
    Clyde Boyer
    Mar 2016
    U.K.
    Part number is 999.651.128.00. It isn’t anything special, just a steel chassis clip.
    Aug 2020
    Shawnee, OK
    Are we sure this clip is for the fuel vent hose? This clip has always been there.
    Pics from Ed and Ravi show this hose above the battery.
    That's for the fuel vent hose on a 69 or later years if a ROW car. Mine is a ROW car but the two hoses in the picture are for the windshield washer and the brake reservoir vent hose.
    Aug 2020
    Shawnee, OK
    Mine is a ROW(German), and now looks great-as was originally intended. Thanks to all for your help.
    I know I have to add the insulator on the positive terminal.
    Apr 2011
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
