Results 1 to 10 of 20
Thread: Battery cable routing
    Aug 2020
    Shawnee, OK
    Drivers side battery cables are a mess. Seems like some of the cables should go above the battery, but there are no clamps to hold them. Anyone have a pic of what they should look like?? 1969
    Thanks in advance
    SteveName:  AD90B581-5BE9-417E-B7C7-C9FB8C5A8190.jpg
    Lightbulb
    Steve,
    This is probably not the angle you need, but this is how mine has always looked .... This shot taken in '08
    Hope this helps...
    Aug 2020
    Shawnee, OK
    Attachment 574902
    Thanks Chuck
    Looks a lot better. My car is smiling!
    Thumbs up
    Well there'ya'go Steve ...
    Cheers
    Slip your cables behind the battery hold down strap, keeps them out of the way
    Steve, u should install the rubber insulation blocks on your positive cable ends of the batteries, available from Porsche. Pix shows one installed and one upside down so u can see the profile.
    Aug 2020
    Shawnee, OK
Size:  95.3 KBDavid- that was a great idea! Gled49, I will order those insulators—which reminded me of a stupid thing I did when I was only using one large battery. I will start a thread of stupid things, so others may not repeat mistakes!
    I did add a hose clamp for the top wires that uses a fender screw.
    cable routing
    The accessory wires route along the hood cable tube and are attached to it with a WHITE ty-wrap, the battery cables run along the trunk floor and bend up to the battery positive post.
    Aug 2020
    Shawnee, OK
    Ed,
    That looks great! I will have to work getting my cables too look like yours.
    I checked and Wire ties have been around since the 1950s. I don't know any place else they were used on my 1969.
    Jun 2012
    London, Ontario, Canada
    Perhaps helpful. I believe it is done right.
    Ravi
    Early 911S Registry # 2395
