Page 4 of 30 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 297
Thread: The Bob Joyce thread!: Restoration of a 1968 911 L Targa
  1. #31
    Aug 2017
    el sobrante ca.
    While the paint is drying..........
    I used the left-over leather from my Roadster to cover the Targa top parts
    although i can only assume that the top was the original
    It defiantly had never been taken apart or recovered
    So I decided to do the restoration as it was.
    Special Note: They used plastic rivets in such a way that is was really hard to recover.
    A few of the plastic rivets' are under the leather and attached to the top "arm".
    you have to attach the piece while at the same time recover the "arm"
    no wonder there are so many variants to the early top coverings............
    Sorry ... cant post pictures
    I am getting a security certificate message.
  2. #32
    Aug 2011
    Eugene, OR
    Quote Originally Posted by bob joyce View Post
    Bob, I sure wish you were posting all this in a dedicated thread on your car's progress, rather than the "What I did today" thread. It would be too much easier to follow if other people's happenings were not interrupting your story.
    Maybe a moderator could copy all your posts on your progress into a new thread?
    - Arne
  3. #33
    Quote Originally Posted by Arne View Post
    Bob, if you’re okay with it, I can move all of these posts to their own thread. Let me know.
    Peter Kane
    '72 911S Targa
  4. #34
    Aug 2017
    el sobrante ca.
    Peter,
    Sure, if you would be so kind to do so....
    1968 911 L Targa
    bob reg#3596
  5. #35
    All set, Bob. Let me know if I missed anything. And I’ll be happy to revise the title!
    Peter Kane
    '72 911S Targa
  6. #36
    May 2011
    Chelsea, Québec
    Awesome work, Bob...
    Member #1616
  7. #37
    Aug 2010
    Colorado
    VERY nice work Bob.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
  8. #38
    How did you get the bolsters attached to the arm. The plastic expanders are behind the rigid foam and under the covering and really hard to line up with the holes in the arms.
  9. #39
    Aug 2017
    el sobrante ca.
    first, fold the leather around the nose of the arm so that it looks correct. only doing an inch or two of the fitting...
    the edge that gets wrapped around the aluminum piece is stretched lengthwise and glued...
    Thien you place it on the arm and puh the rivet into the arm.
    the piece that runs the length of the arm was not folded under and glued
    so... i was able to partially fold it back and then placing a firm piece of plastic on top of the rivet (under the cover) and Wack it down.
    ...also , the new padding was punched where the rivets were to go...
    a couple of the rivets went all the way home by just pushing in with finger...
  10. #40
    Aug 2017
    el sobrante ca.
    for revising the title of this thread ... how about suggestions from the people who want to find it????
    "a grave diggers tale"
    "Just a little buffing sir"
    "magic pen, as seen on tv"
    "The 1968 911 L Targa"
    " Xxxx xxx xxxx?
