Page 17 of 30 FirstFirst ... 7151617181927 ... LastLast
Results 161 to 170 of 297
Thread: The Bob Joyce thread!: Restoration of a 1968 911 L Targa
  1. #161
    Isn’t there a spacer between caliper and control arm? I have some in my box of plated stuff. It’s been a while since I worked on a SWB car. I’ll post a pic if needed.
  2. #162
    These are SWB caliper shims that either go front or rear one some cars, just can’t remember which model. They are 3mm thick.
  3. #163
    Actually making it tighter will make it worse pulling the hub in more. Maybe after torque it will need a 3 mm shim.
  4. #164
    Aug 2017
    el sobrante ca.
    Fantastic Rick
    The book does not show this spacer, but once I saw your picture i remembered that I had painted those pieces years ago...........
    Would you have and be interested in selling some GRAEKA 13MM head, 8MM , 10mm long bolts
    They are for the front and rear brake backing plates. I need 12.
    Greatly appreciated
    thank you
    enjoy
    bob
  5. #165
    Aug 2017
    el sobrante ca.
    with original 3mm shim installed
    caliper centers on disk
    when placing brake pads
    both sides were equal
    Thanks again Rick....Name:  DSCN1581.jpg
  6. #166
    Sorry Bob, nothing with the correct brand
  7. #167
    Aug 2017
    el sobrante ca.
    front suspension installed...
  8. #168
    Aug 2017
    el sobrante ca.
    Front brakes installed except that i have the wrong bango sealing ring..........Name:  DSCN1584.jpg
  9. #169
    Apr 2013
    Clayton, NC
    Bob - great thread!
    Did you paint or coat the front hubs to protect them? They look a little brighter than just polishing.
  10. #170
    Aug 2017
    el sobrante ca.
    yes... they were oxidized and once cleaned up i wanted to stop the oxidation process
