Page 14 of 29 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 283
Thread: The Bob Joyce thread!: Restoration of a 1968 911 L Targa
  1. #131
    Aug 2017
    el sobrante ca.
    this particular chrome piece is the stopper ....
    the chrome guys won't refurbish piecesName:  DSCN1444.jpg
Size:  116.9 KB with this much rust
  2. #132
    Aug 2017
    el sobrante ca.
    In stalling duct works.....Name:  DSCN1457.jpg
Size:  119.0 KBName:  DSCN1454.jpg
  3. #133
    Aug 2017
    el sobrante ca.
    addressing wiring loom holders...
  4. #134
    Aug 2017
    el sobrante ca.
    Accelerator rod bushings installed.
    Also, in picture restored shift coupler.........
    And improved (Much wider) shift rod bushing........Name:  DSCN1464.jpg
  5. #135
    Aug 2017
    el sobrante ca.
    installed heater box/valves.Name:  DSCN1466.jpg
    also test fit Mercedes W108 breakaway mirror plate...........
  6. #136
    Aug 2017
    el sobrante ca.
    got some goods from overseas...
    these rugs are Porsche color burgundy.
    They are actually a little warmer/darker than the pictures.
    trunk too............
    and some phony axx expansive Vinal that was supposed to be Targa top material...
    i am an upholstery guy so don't ask me about the quality....... it is too embarrassingName:  DSCN1473.jpg
Size:  85.0 KBName:  DSCN1469.jpg
  7. #137
    Aug 2017
    el sobrante ca.
    Here is a 1969 Mercedes mirror Stem... ( Top)
    And a 1968 Porsche mirror stem furnished by Jim B. (Bottom)
    They are identical in every way.........Name:  DSCN1476.jpg
  8. #138
    Aug 2017
    el sobrante ca.
    Installed the gauges.
    I wanted to finish building out the tunnel so i needed to install the loom.
    Started at the front of the car passenger side and fished the wires up the fender support to find that it is about 12"Name:  DSCN1482.jpg
    " to short...............
    So then mocked up the rest of the loom all the way back to the taillights.
    Luckily that part of the loom appears to fit..........
  9. #139
    Aug 2017
    el sobrante ca.
    Installing the main loom......Name:  DSCN1483.jpg
  10. #140
    Bob, check that actuating arm from the brake switch, I think its on the wrong side of the washer.
