Page 12 of 30 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 296
Thread: The Bob Joyce thread!: Restoration of a 1968 911 L Targa
  1. #111
    Aug 2017
    el sobrante ca.
    Air vent installed and fully operational...........
  2. #112
    Aug 2017
    el sobrante ca.
    the glove box needed repair.
    i filled in a few holes then sanded the inside with 220 grit.
    painted the inside with dark grey rust-oleum.
    then flocked it with dark grey flock.
    i will let it dry overnight and then blow off the excess.
  3. #113
    Aug 2017
    el sobrante ca.
    Wipper unit .... cleaned up nicely ....Name:  DSCN1427.jpg
  4. #114
    Apr 2013
    Clayton, NC
    Looks great. Did you paint or plate the linkage?
  5. #115
    Aug 2017
    el sobrante ca.
    the linkage was plated.
    I bought the parts minus the motor a few years ago as i remember on this site.
    turned out that the bracket that was powder painted beautifully had the wrong bolt pattern for the motor, the 3 bolt holes for some reason were clocked back about an hour and the supporting small tab was also askew.
    I refinished my original motor bracket and was able to remove the entire linkage and place it into my part. It was tricky but worked.
  6. #116
    Apr 2013
    Clayton, NC
    Very nice job. That part looks brand new.
  7. #117
    Aug 2017
    el sobrante ca.
    pulled the plate off and dug the waxy grease out .... regreased it
    So, after 40 plus years sitting in a field, it ran like a sewing machine.
  8. #118
    Aug 2017
    el sobrante ca.
    My gauges for my 1968 911L Targa.
    John Bell sympathetic restoration.
    SPECIAL NOTE: Font is Ivory. not green not white. early cars have 3 different font colors.........
    Tachometer upgrade card installed..........
    ATTACH=CONFIG]584416[/ATTACH]
  9. #119
    Aug 2017
    el sobrante ca.
    finishing up the glove box...
    leather dye worked well on the pressed paper material...
  10. #120
    Nice Bob, isn’t flock a cool product. Fairly easy to use and it fairly cheap.
