Page 4 of 23 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 230
Thread: 72 RS Prototype Hot Rod Build!
  1. #31
    Feb 2003
    Los Angeles
    This is a very cool build. Can you tell us where you had the steering box rebuilt?
    I'm looking forward to the finished car.
    Quote Originally Posted by Longballa View Post
    Suspension details:
    Elephant sport rubber bushings for A-arms, camber plates, spring plates and trailing arms.
    18mm front sway bar kit. 18mm rear sway bar.
    Aluminum 74-77 trailing arms.
    20mm hollow front torsion bars and 26mm rear.
    Rebuilt steering rack with Turbo tie rods and Elephant drop link tie rod ends.
    Bilstein front struts with 16mm raised spindles. HD inserts.
    HD rear shocks.
    Elephant adjustable spring plates.
    65mm front and rear titanium wheel studs and titanium lugs.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
  2. #32
    Jul 2006
    Corvallis, OR
    Sure Bert, 914rubber.com click under the services tab on their website and you'll see it.
    72S, 72T now ST
  3. #33
    Feb 2003
    Los Angeles
    Awesome. Thanks Scott.
    Bert Jayasekera
    R Gruppe #167
  4. #34
    Jul 2006
    Corvallis, OR
    It's always a big accomplishment when you get to primer day! Even a rust and accident free chassis takes a lot of time to get to this stage. Anytime you do a color change it's just a ton of work. Anyway, flares are on, gaps are dialed in and primer now drying. Paint and body work just simply takes a lot of time, beats up your body and gets you dirty as hell.
    72S, 72T now ST
  5. #35
    Jul 2006
    Corvallis, OR
    I've bumped up a couple of things on the build. Now it will be a 3.5L engine built by Rothsport instead of the 3.2! GT3 crank, ported heads, twin plug, EFI and all the good stuff. I'm also going to install right off the bat the Elephant 930 brakes which I always was going to do anyway but I thought I'd start with a set of S brakes I had restored but nope right to the 930's with the added HP.
    72S, 72T now ST
  6. #36
    Scott,
    Whoa. That engine will pack some hella punch.
    Having a been a painter in the early days the primer is the best of all the steps. Color is fun, but not relaxing like the primer.
    Bill
    1969 911T - sold
    2001 911 Turbo - sold
    1996 911 C4S - returned
    1982 911SC - gone
    1960 356 Roadster - sold
  7. #37
    Aug 2017
    el sobrante ca.
    when you shoot the primer, not the action of just covering the bare metal, but actually are priming for the purpose of the sanding out phase
    That is truly a special time
  8. #38
    Jul 2006
    Corvallis, OR
    Quote Originally Posted by 911TES View Post
    Scott,
    Jeff built me a 3.5 for my ST years back it was just the best engine I've ever owned! I'll post dyno results when it's done.
    72S, 72T now ST
  9. #39
    Jul 2006
    Corvallis, OR
    Elephant calipers and hats bolted up to restored hubs with 65mm titanium wheel studs and lug nuts.
    72S, 72T now ST
  10. #40
    Feb 2003
    Los Angeles
    The 930 brake set up looks great. Can you tell us the weight penalty when you use larger 930 rotors over the 911S brake set up that you originally intended?
    Bert Jayasekera
    R Gruppe #167
