Thread: Gas Lid Latch Spring
    Dec 2013
    Connecticut/Florida
    Just wanted to check....
    I know there is a spring on the Gas Tank lid/door itself. But is there a spring inside the latch itself? Parts diagram doesn't show one, but some online posts indicate there might be one. If not, how does the Latch return to its position after you pull it to open the door? or do you manually push back the pull cable ?
    1971 911S Coupe - Gemini Blue
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    yep there is a spring...similar style as for the lid itself.
    And woe be to those who remove that spring during restoration and then must re-install it as part of the release/catch unit.
    Dec 2013
    Connecticut/Florida
    Thanks - I found the spring
    Oct 2010
    Southern Ca.
    Yes , don't try to install after the filler neck and seal are installed .
    Oct 2009
    Indiana
    to "Richy" and Jim Morris", i enthusiastically agree.
    MAKE SURE THAT LATCH ASSEMBLY IS FUNCTIONAL AND INTACT BEFORE INSTALLING THE FENDER!!!! Otherwise, you are in for a LOT of pain.
