Results 1 to 7 of 7
Thread: 1970 911S Hood compartment color
    Junior Member
    Mar 2017
    Golden - CO / Milan - Italy
    Hello to everybody. been registered for a few years but never really posted. I'm finally getting my hands again on my dad's 911 after several years that has been parked in a friend's garage after my dad's passing and since he really loved this car I want to make sure it is just as good and correct as it can.
    Here's my question for whomever will be so kind to pitch in and share his knowledge with me. I'm trying to understand the correct color that should be in the hood compartment. The car had been partially restored in the 90s and the only image I have of the compartment is one with an angle and a light that would make me think was originally blue but I simply couldn't tell. The whole question deal is because in the early 2000s my father had the car get a certification from the Italian historical auto moto club and the person that inspected it had noted that the color should be black. Since I'm not completely sold on this and since the car is now at the body shop to fix a couple of scratches I might as well have the area painted correctly if it needs to be black vs/body color.
    Pictures of the area of original survivors would be greatly appreciated.
    Alex
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    depends on where it was built and probably also on the exterior colour.. here`s 4 examples i had in house...
    left is karm. right is porsche
    you probably can find traces of black on your car if it ever was black
    what about the engine compartment and floor on yours?
    Junior Member
    Mar 2017
    Hi Moito, thanks for replying to me. So I know the color is 8484 metallic blue (color code 324?). I'm not close to the car and for some reason I can't find a picture of the tag that if I remember right says (correct me if I'm remembering wrong) if it was a Karmann or not. The floorboards are black and the engine compartment I believe is black as well.
    In 1970 the trunk was body color, unless it was built by Karmann then it was black, but I don't believe Karmann built 'S's .
    Jul 2003
    Santa Cruz, CA
    Agree with Ed. I don't know of any Karman built Esses. Body color in the trunk but, lightly sprayed, almost overspray look. Engine compartment is brush applied black over body color. Likely applied at the same time as the undercarriage strips along the rockers and wheel wells.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Original Trunk Finish
    Quote Originally Posted by autogatto View Post
    . . . trying to understand the correct color that should be in the hood compartment . . .
    . . . Pictures of the area of original survivors would be greatly appreciated
    Here's some shots of 9110301353 --- aka 'the 700-mile S' . . .
    https://www.early911sregistry.org/fo...l=1#post442264
    My car 's not handy but the trunk finish looks more like 'over-spray' vs actual/proper paint. There's also a liberal amount of what I call 'tar-slap' applied to the tops of the shock mounts. Then there's also what looks an awful lot like contact cement smeared on the inner fenders --- to keep the trunk carpet from moving around too much, I guess
    Very decorous . . . and almost always sanitized/restored/cleaned/defiled = missing at some point
    And wait 'till you look inside the 'smuggler's box' . . .
    https://www.early911sregistry.org/fo...ow+smuggler%27
    . . . yeeechhh!
    PS . . . WAY more OG-ness, here . . .
    https://www.early911sregistry.org/fo...highlight=show
    I've seen base coat only used in the front compartment, gets close to that thin dry look of the original cars that were body color up there
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
