Thread: Tire Pressure Recommendations
    I recently competed a mechanical restoration of my 1970 911T. It has new Pirelli CN36 185/70-R15 tires on 5-1/2" steel rims, Koni shocks, bearings, ball joints, tie rod ends, half shafts, and torsion bar bushings in addition to a rebuilt engine and transmission. A suspension shop recommended by my mechanic finished the job by replacing the rear torsion bar bushings and doing a corner balance and four wheel alignment. I was surprised to see that they set the tire pressure to 28 psi front and 34 psi rear, so I checked the operator's manual and it specifies 26/29.
    The ride seems harsher and noisier than I remember, but I have not driven it or any other sports car for 30 years. Am I a victim of a poor memory and expectations formed by modern seats and suspensions? Have years of experience and material upgrades changed the recommendations on tire pressure? Am I likely to find the ride better by returning to the original tire pressure recommendations? I'm seeking advice on how I should adjust my expectations and/or tire pressure for street driving that will rarely rise to the level of "spirited".
    BruceE
    Lower the pressures and see if it helps. I like them better set higher. but you may not. Easy enough to try.
    Aug 2011
    Eugene, OR
    No harm in trying them at the factory pressures. I don't think I'd want to go lower than that, however.
    Actually, since you are running them on 5½" wheels, the lower factory pressures may work better since the tires might not "crown" as much.
    - Arne
    Bumping this older thread as I was looking for a reference. May help others.
    Peter Kane
    '72 911S Targa
Tags for this Thread
