Results 1 to 10 of 10
Thread: Wire motor question
    Aug 2010
    Wiring of noise suppressor on windshield wiper motor
    The car is a 69E. Were does the black noise suppressor wire go? It's not on the diagram nor a wiper relay. None on a 69? I had the suppressor at 53E and kept blowing out the number 4 fuse.
    One other question. What is that little box (double red wire) in the wire diagram. I don't see a place on the motor for this.
    Thanks.
    Chris
    Dec 2013
    Connecticut/Florida
    Partial help? my 1971
    1971 911S Coupe - Gemini Blue
    Dec 2013
    Connecticut/Florida
    another photo
    A bit dark
    May 2006
    CT
    Here is a photo from the disassembly of my '70E
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Aug 2010
    I’m still trying to figure out where the black and brown wire go. I see one of the suppressors has a red wire? Brown should be ground. But the black I’m unclear. The black wire can’t be unplugged but the brown wire can.
    Red from 53a replaces the brown on the capacitor (shown in that little box) black goes to 53a
    Brown goes to a terminal on the body of the wiper motor (ground)
    Aug 2010
    Thanks Timmy,
    It works perfect.
    No problem, happy to help.
    Boy that harness sure looks familiar.
    Aug 2010
    Timmy2,
    It should.
    Another question. Should the suppressor be mounted off the motor. Will it pick up machinal or electric interference mounted to the motor?
    Any place convenient that is grounded to the body is fine.
    The suppressor is there to remove that noise.
