Thread: Gasket/Seal Ring For Oil Pressure Sensor On 2.2 Litre (1970)
    Hello to All
    Is there any type of seal/crush washer between #59 (pressure transmitter) & #61 (reducing socket) on a 2.2L engine? Given the notoriety of the location of these particular parts, it seems somewhat counter-intuitive there not be a gasket or seal washer required as this “snip” from the PET appears to indicate. If in anyone's experience it is advisable to install such an item - any suggestions are most welcome.
    Name:  Oil Pressure Seal Ring-A.png
    Also when re-installing the transmitter, how much ’torque’ (a subjective value in this case) is required to ensure a proper seal between the components? The “torque wrench” in my wrist is of dubious accuracy so any suggestions to ‘ball-park’ a reasonable amount of torque or 'a tightness' value will be most appreciated.
    Thanks & Cheers
    JB
    Success is not final, failure is not fatal: it is the courage to continue that counts. - Winston Churchill
    Early 911S Registry Member #3749
    If memory serves the sending unit comes with a washer on it, but if not just use a normal aluminum sealing ring. As to the torque I have no idea, its a feel you have when you've done this for 60 years. I would say its the tightening force you can get with a normal end wrench. You don't need a 3 ft. lever!
    Oct 2010
    Southern Ca.
    Some sending units need a sealing washer , some have a tapered thread .
    Hey guys -Thanks for your inputs - very much appreciated.
    Cheers
    JB
