Thread: mfi question
    mfi question
    On a 005 pump the throttle connecting rod should be 114+/- .2mm ball socket center to ball socket center. If the engine runs best with a length of 116mm, how many clicks of the partial load enrichment screw is the equivalent? How many clicks per mm ? Knowing this would save a whole lot of time. Thanks in advance.
    Oct 2010
    Southern Ca.
    Adjust the screw for the main rack . Turn it counter clockwise 3 clicks to enrichen and test . Maybe try again . At this point in time do not play with the partial enrichment screw . I forgot to include to first adjust the throttle connecting rod to 114 mm .
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Quote Originally Posted by sanders View Post
    Not really the best way to fix this problem. The MFI pump throttle connecting rod should be set at 114mm. Having it set at 116mm adds 8 to 9 degrees of space cam throttle rotation and throws off the fuel mapping. Playing with the main rack adjustment to compensate for misaligned linkage will most likely add more problems. I would set the pumps 114mm rod correct, make sure the TB's are set correctly and then re-adjust the throttle bar drop links so they snap on without any pressure on the ball sockets. Now if the engine needs AFR's adjustments you can do it knowing the linkage is set correct. We could go deeper with the TB's adjustments but I'm hoping there close.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    I just went through a similar issue. This thread might be of help to you.
    https://www.early911sregistry.org/fo...23#post1078823
    Once you let the smoke out, It's hard to put it back in
    May 2006
    CT
    Sanders
    You inbox is full and I cannot reply to you recent PM. Please let me know when you have cleared it.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
