Results 1 to 5 of 5
Thread: 1965 911 Engine or Case 903-2XX
    Hi
    I am shopping for a 1965 911 engine between numbers 903-200 and 903-220. I am buyer for the entire engine, or just the case.
    If you have an engine in this number series that is in your car but not matching to your car, I can supply a period correct engine, and funds, as part of the purchase.
    The engine that came with my car is not matching numbers and I am trying to find the correct engine. The engine I offer, if a swap is desired, is an early 1966, number 907-641.
    thanks
    Tim
    Feb 2012
    Netherlands, Leiden
    Hi Tim,
    You can search the site with this query: 9032*
    All results starting with 9032 will be showed.
    Two older threads mentioned engines in your desired range:
    903202
    https://www.early911sregistry.org/fo...%2A#post778248
    903225 (5 numbers off, but still close)
    https://www.early911sregistry.org/fo...%2A#post580071
    Good luck with your search!
    Thanks Jesse
    Tim,
    I have a couple earlier and one a little later...cases or complete engines. If interested send me an email...I'm in CO.
    registry# 1283
    Thanks Speedo,
    Sounds similar to my situation; I am all set with earlier and later number engines.
    Cheers
Tags for this Thread
