Results 1 to 10 of 13
Thread: Free: early pivots
    Free: early pivots
    GHE pivots can someone please identify for me
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Those look like the same pivots I just had to find for my '65 project. Outers I believe as the inners have smaller diameter pegs. I think they're 65 and 66. Maybe 67 too?
    Thanks John
    Clyde Boyer
    Jul 2008
    South Florida
    What John said, up to '67 (and very early '68)... the inner pins are 5mm, outer pins are 8mm. Just discovered this after ordering a replacement set from Sierra Madre and finding they don't fit.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Anyone need the pivots, free to a good home just the cost of shipping from down under if they are in fact worth that much (maybe $25 USD for shipping)
    Clyde Boyer
    Jul 2008
    South Florida
    If they're 5mm Clyde, I'd be pleased to have them and thank you kindly!
    Russ
    ESR # 1537
    '70 914/6 GT
    They are 8mm posts Russ if they are no good for you an Aussie has put his hand up for them
    Clyde Boyer
    Jul 2008
    South Florida
    To your countryman then, Clyde. I need a nice pair in 5mm. Good on ya for offering them.
    Russ
    ESR # 1537
    '70 914/6 GT
    Aug 2009
    SF Bay Area
    FYI: The pins can be interchanged easily. I use a heat gun and heat the plastic just enough to loosen the pin. Pull it out and install the larger or smaller pin (they both have the same base) with a bit of epoxy.
    Jim
    If you still have these, I could use these for my early '66 (Nov. '65 Build)....
    Thanks, Dan
