Page 33 of 44 FirstFirst ... 23313233343543 ... LastLast
Results 321 to 330 of 435
Thread: 300090
  1. #321
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    thats very odd...all but one early cars i`v had a closer look at had this tube...but it was different compared to later cars....it reaches way shorter into the passenger compartment...and it was made from 3 pieces...a short one in the trunk and a long one that goes inside +it was connected with a short metal sleve(hard-soldered)
    the one exception was a car t i did not see as a good reference car since it had a massive front fender bender ....it had a bowden cable
  2. #322
    Hood Pull
    Here is a photo from car 149. Looking up from the floor you can see the the Hood Pull in relation to the gas lid release ring lever.
    The Hood Pull is further forward than in 1965 and all later cars. It was about 50mm longer reach to find it.
    Look closely to the inner fender for remaining spot welds and the opening (hole) in the side of the hood latch support, is there any evidence of the tube
    being there at one time?
    Bob
    Early S Reg #370
  3. #323
    Senior Member 300090's Avatar
    Sep 2019
    FRANCE
    Guide tube for cable control
    Thanks to you Franz and Bob.
    I'll be watching this very closely when I'm with the car.
    In the meantime here is a photo taken just after stripping.
    Do you see anything interesting? (Please, ignore the screw in the red circle)
    Philippe
    Quote Originally Posted by Bobs 67S View Post
  4. #324
    May 2013
    AUSTRIA (tu felix)
    300096 ..... will look for better pics of the tube-sleve situation
  5. #325
    May 2013
    AUSTRIA (tu felix)
    an other thing you maybe want to know is that the shape of the cutout in the door stop area is different on early cars...the reason is that the tap where the door stop is connected to the A-pillar has a slightly different shape ,so if you are useing a newer door it is very likely they would collide when closing the door...
  6. #326
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by 300090 View Post
    ..... (Please, ignore the screw in the red circle)....
    Philippe
    nothing wrong with that screw
  7. #327
    Sep 2019
    FRANCE
    Thank you very much Franz!!!
    It would be great if you could find pictures that show the path of the tube in the front trunk under the dashboard.
    Philippe
  8. #328
    May 2013
    AUSTRIA (tu felix)
    Philippe
    here you are
    red circles indicate where it is hard-soldered(300113)
  9. #329
    May 2013
    AUSTRIA (tu felix)
    since there is no tube installed in your car i would first look if there is any indication /traces if there ever was one installed....would be quite odd if someone removed the tube and even more odd if he did also perfectly remove every evidence.
  10. #330
    Franz your documentation is just outstanding.
    Bob
    Early S Reg #370
