Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 66
Thread: Accelerator linkage adjustment
  1. #31
    Looks like you need to replace those bell crank bushings. It also looks like the bushing in the clutch arm is worn out.
  2. #32
    Apr 2003
    Portland, OR
    Hi Ed. I have a quick question, in my 1973, I believe there are 2 throttle rod bushings. Is one accessed under the shifter and the other at the rear shift coupler access panel? Thanks!
    Harry
    Member #789
    2009 MB C300
  3. #33
    Sep 2018
    Netherlands
    If you mean the white plastic bushes in the tunnel, there are three. One under the shifter, one under the handbrake, and one under the rear panel -- that's the only one that's easy to access.
    1970 2.2S Elfenbeinweiss
    2002 996 TT Midnight Blue
    Member #3833
  4. #34
    Apr 2003
    Portland, OR
    Quote Originally Posted by frederik View Post
    Per the PET, there are only 2. Hence my question to Ed.
    Harry
    Member #789
    2009 MB C300
  5. #35
    I don't know why you're missing the third, but trust me, it's there.
  6. #36
    Apr 2003
    Portland, OR
    Ed,
    I know second guessing you is fraught but... this is what the PET for the 1970-73 vars shows. It certainly confuses me.
    Harry
    Member #789
    2009 MB C300
  7. #37
    Lightbulb
    Harry,
    Sometimes the PET just doesn't correspond to date specific information.... or sometimes the correct information
    Here out of my '73 Parts manual printed 9/72
    Hope this helps
    Apr 2003
    Portland, OR
    Chuck:
    Thanks. For some reason this does not surprise me. I just want to be sure.
    Harry
    Member #789
    2009 MB C300
  9. #39
    Thread Killer dummkopf's Avatar
    Jun 2011
    Mound, Louisiana
    Thank you Mr. Miller. Something I need to check on!!!
    72 911S Targa #0807 95+% German.
    Paul Harrop 12.5% German.
    Early S #2059
  10. #40
    Hi All,
    I found out my trans bell crank was for 915 gearbox so I decided to install the correct 901 one for my car as well as the main pull rod.
    Here is the 915 bell crank :
    And here are the right parts :
    I was a little bit short while connecting all together, so I decided to order also the extension rod which is linked to the rubber connecting piece, and I was right :
    Now all angles on the 3 bell cranks are good (as described by Ed) and I have full throttle movement.
    Name:  throttle linkage.jpg
    Since then I'm trying to adjust the return to idle position when I release very slowly the accelerator pedal, time to time it doesn't go fully to that idle stop position and it does not engage the microswitch in the engine compartment.
    It looks like if the pedal was sticky within the last inch of its course.
    All my bell crank bushings and the 3 in the tunnel are new and there was no problem before I did that job...
