Page 3 of 33 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 330
Thread: Flares.....
  1. #21
    Senior Member Darren65's Avatar
    Aug 2011
    UK
    Specification....
    ...provisionally....
    VIN: 9117601003
    Engine: 6671322 - 930/02
    Gearbox: 7174852 - 915/61
    Production Date: 01/03/1977
    DOR: 13/05/1977
    Original Specification:
    1977 911 Carrera 3.0 Manual RHD
    New Specification:
    1974 911 Carrera 3.0RS Build
    Engine:
    930/02 Aluminium Cases to 3.0 RSR twin-plugged competition spec
    95mm Bore with 70.4mm Stroke
    RSR Cams
    Slide Valve Induction
    Bosch Twin Spark Distributor
    226mm Small Fan Housing
    Racing Oil Filter - Disk Type
    Modified Racing Fuel Pump to 3.0RSR Specification - Gus Pfister at Pacific Fuel Injection
    Racing Pump Support Brace and Base
    Lightweight Clear Engine Shroud
    Racing Headers
    Twin-Out Rear Muffler
    Gearbox:
    915 Manual Gearbox to competition spec
    Custom Gear Set - TBC - Guard Transmission
    Guard Transmission Limited Slip Differential
    Custom Side Plate with 930 Bearing
    RSR Type Oil Spray Bar with right side oil pipes and Trombone Oil Cooler
    Strengthened Main Shaft
    Body & Interior:
    Strengthened jack, suspension, torsion tube, ARB mounts and engine points
    Nose modified for front central oil cooler
    RSR Steel Arches
    Glass bonnet, front & rear bumpers
    Small & Large Whale Tails
    RSR Type Front Brace
    110L Plastic Fuel Tank
    Central Front Oil Cooler
    Clock Delete
    10K Tacho
    180MPH Speedo
    Lightweight Needlefelt Carpet
    RS Type Rubber Matting
    Half Roll Bar in 40mm tubing
    Black Head Lining
    Lightweight RSR type door cards with strap pull door release
    Lightweight RS Type Drivers & Passenger Seats
    Lightweight Recaro Seat Sliders
    Fat Steering Wheels
    Repa Harnesses
    Suspension, Brakes & Wheels:
    Bilstein Front & Rear Dampers
    19mm Front Torsion Bar - 18mm Fixed ARB
    26mm Rear Torsion Bar - 18mm Fixed ARB
    Short Strengthened Rear Arms
    917 Callipers and Disks
    Rubber Bushing
    9" Rear Fuchs with 235/60R15 Tyres
    8" Front Fuchs with 216/60R15 Tyres
    Paint:
    Mexico Blue
    No underseal
    ....here I could do with some help?
    These cars were developed so much in period, looking through countless old photos, it's hard to determin the exact specification when new......is a half roll bar correct, did they have aluminium door skins etc etc?
    I'd welcome all opinion on what items this car should, or should not, be equipped with?
    Cheers,
  2. #22
    #2922
    Oct 2010
    Sweden
    Quote Originally Posted by Darren65 View Post
    Here are 5 pages from Christophorous no.1(?) 1974, they tell a lot.
    no opinions yet on what items to have on it
    Bengt
    Light Yellow -74
    @lagteknik
  3. #23
    Senior Member patrick911's Avatar
    Mar 2007
    Melbourne, AUS
    ....anyways, you can't be building a solid RS/RSR without short arms and last week I picked up a pair from my good friend Ben Coles....shown here with a standard arm for comparison.....
    Great update Darren.
    I got the shortened trailing arms from Ben as well. Not at the stage to put them on yet but they look beautifully manufactured!
    Is he still making Porsche stuff or is he focused purely on other items nowadays?
  4. #24
    Thumbs up
    Over here now Darren...You'll still get plenty of help and suggestions...As Gib got with his projects...
    Cheers and good luck
    Aug 2011
    UK
    Quote Originally Posted by gtBen View Post
    Bengt
    ....that's very helpful, thank you Bengt
    Quote Originally Posted by patrick911 View Post
    ....Ben still has his stock although his focus is elsewhere at the moment and I don't think he's manufacturing much.....best be quick if there's anything else you need!
  6. #26
    Aug 2011
    UK
    No worries Chuck although these cars will always be a continuation of the longhood racers in my eyes
  7. #27
    Nice one darren,watch ben dont get you into traction engines
    You need some ultimate trick dampers with coilovers,give them pesky torsion bars a miss.
  8. #28
    Darren, I have factory info and willing to help out...let me know if you need something...
    Ernie W
    member of Early 911S Registry
  9. #29
    Aug 2011
    UK
    Quote Originally Posted by Yellow491 View Post
    Lol....I'd need to be Herefordshire Landed Gentry to fund a Traction Engine habit!!!
    Although we'll make the mods required I've no plans to fit coil overs but maybe a future development as it will have many out and out racing parts.....doubt I'll ever get close to your tail though Paul
    Cheers,
  10. #30
    Aug 2011
    UK
    Quote Originally Posted by Ernie W View Post
    Huge thanks Ernie and much appreciated.....I dare say I'll be calling on you soon
