Page 28 of 32 FirstFirst ... 182627282930 ... LastLast
Results 271 to 280 of 320
Thread: Flares.....
  1. #271
    Senior Member Darren65's Avatar
    Aug 2011
    UK
    Sadly not quite young Jens although appreciate the kind words
  2. #272
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Yeah, I was young once, too.
    RGruppe #183
  3. #273
    Senior Member patrick911's Avatar
    Mar 2007
    Melbourne, AUS
    Perfection - as we have become used to in this thread. Awesome job Darren, and thanks for sharing.
    Seeing there's an update on your project always adds a smile to my morning.
    Member #3508
    1973 911 2.4T
    1976 911S -> 2.8RSR replica
    "if nothing goes right, go left!"
  4. #274
    Aug 2011
    UK
    Thank Patrick, I appreciate the kind words.
    It's been a lot of work and of course it was never the plan to start producing oil coolers but, as you well know, sometimes you have to improvise!
  5. #275
    We had some R projects, needed a couple coolers so we made a dozen pairs of accurate repo bar and plate coolers. We started early, it still took a couple years, they were finished before the projects end. Your project looks great.
  6. #276
    Aug 2011
    UK
    Thanks Gled, apologies I forgot to reply that those are very cool items!
  7. #277
    Aug 2011
    UK
    Oil Coolers Completed and FOR SALE....
    I collected my completed batch of oil coolers.....
    ....and took them to have the Aluchrom 407 protective coating applied.....
    ....I have a few of these now available for sale....
    https://www.early911sregistry.org/fo...ral-Oil-Cooler
    Many thanks,
  8. #278
    Sent u a PM. Are u going to run a scavenger pressure relief that dumps into the filler neck? And what pressure relief did u use in the cooler? Gordon
  9. #279
    Aug 2011
    UK
    Thanks Gordon,
    Yes will be fitting a relief valve in the engine bay.
    As you probably know the cooler valve is quite a simple thing and I'm told there's very little chance of it ever being needed and only in the event of a crimped pipe causing a surge etc.
    I was able to obtain all the valve/spring dimensions etc from an original RSR cooler that was being re-cored and the springs were fabricated using the same wire thickness, number of coils and overall length....
    HTH.
    Cheers,
  10. #280
    Aug 2011
    UK
    Engine Coolness...
    With the engine build soon to hit full throttle I've been collecting the final items needed for the build....
    ....I'd initially thought about fitting solid rockers although ultimately decided to fit Schrick adjustable racing rockers. Given the amount of road miles this car will do as well as track use I feel they're a sound choice and will help when it comes to maintenance.
    These are forged CNC milled part used in many race engines, lighter and stronger with a DLC coating and an extended contact area between cam and rocker, they're ideally suited to race cams.
    Still eye-wateringly expensive but damned cool and very sexy .....
