Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 72 T brake upgrade question..
  1. #11
    Carrera calipers require Carrera rotors. Carrera rotors are thicker than SC and earlier rotors.
    Carrera and SC front calipers are virtually the same except for a slightly
    Wider spacer between the halves on the Carrera calipers.
    The rear calipers on a Carrera have a slightly larger piston and a different entry point for the brake
    Line than SC calipers (that are virtually identical to your 73 calipers).
    One of the tricks used to get the thicker rotor on Carreras was to use a slightly
    Larger spacer and use a thinner pad. Carrera pads are like putting SC pads that are half
    Worn out on your car.
    Jim
    Jim - thank you for taking the time to provide such helpful information - most appreciated!
  2. #12
    Feb 2012
    Sweden
    Is there a noticeable difference driving wise between the SC and Carrera calipers? And is there a noticeable difference in thermal capacity between the two rotors? Considering both track and street driving
    -70 911E
    -84 3,2 Sold
