Results 1 to 10 of 20
Thread: FS: 911 Door Hinge Bolt, 999.509.001.02
    These bolts were used from '66-Mid '72. They have the correct 12 point, triple square, XZN recess and replace the NLA:
    WET '65-68 911 Fig 8/6 #3) 999.509.001.02 Cheese-head screw, M08x1.0x15 Qty: 12
    Door hinge bolts '72): 900.075.085.02 Hexagon-head bolt, M8x20.
    Material: Titanium, Gr 5 (6AL-4V)
    Finish: As machined
    Weight: 5.72 grams (4.36 grams lighter than OEM)
    They come with the choice of several washers (#7) :
    * 1 Washer, lock, split for 'standard' 911
    * 1 Washer, lock, split for cap screws (non-OEM, but I think they look cleaner)
    * 1 Washer, lock, Toothed for other models
    * 1 Washer, lock, Belleville/Schnorr for believers
    These bolts require an M8 XZN socket, preferably 3/8" drive, impact rated. Non-impact socket sets can be found cheaply on eBay (US seller, lifetime warranty). They can also used on the door striker bolts. An impact wrench, impact hammer, or 24" breaker bar will aid in bolt removal.
    The bolt's price is $5.33 each ($31.98 per door set of 6, $63.96 per car set of 12).
    Shipping within the US is by USPS First Class Mail (varies by destination, ~$5.00). Priority Mail is available for $7.20 (As of 2023 it is $10.20!).
    Other parts available:
    Key Words: XZN, 99950900102, N 0147074
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Aren't they used until March/April 1972?
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    Quote Originally Posted by dirk07 View Post
    yes changed to hex during my72 not sure what month
    good morning for the 1970 door screws can you ship to me in Canada? L6J5R1
    thank you
    Hello mgageoff,
    Yes. Shipment costs to Canada by USPS International Mail $14.25 and USPS Priority International Mail $28.50.
    Quote Originally Posted by mgageoff View Post
    thank you
    Sep 2006
    La Quinta
    How much are the grill nuts?
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Hi John,
    The grill nuts referenced in the first post are $4.94 each.
    Quote Originally Posted by John Straub View Post
    Jun 2012
    Corry, PA USA
    I would like a set, no washers needed as I plan to use Schnorr. Are these 15mm for 70 911? I would like a set of 12. Karl at www.thoroughbredmotorsports.com
    Hi Jimmy,
    Are these bolts still available? Are these 15mm or 20mm thread lenght?
    If these are 20mm (hopefully for me) I would need 2 complete car sets.
    Can you contact me by email please, I can't PM as I am "too young" in this forum.
    claude . cot3 @ gmail . com
    Thank you
    Quote Originally Posted by Claudecot3 View Post
    Hi Jimmy,
    Thank you
    Hi Claude,
    These parts are still available. They are identical to the OEM bolts, WET '65-68 911 Fig 8/6 #3) 999.509.001.02 Cheese-head screw, M08x1.0x15 Qty: 12.
    There were some longer 20mm grip length bolts used briefly before they were changed but I don't know the part number and don't produce them.
    Good luck in your search.
