Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Recaro IdealSitz-S Help Needed
  1. #11
    Quote Originally Posted by Buster View Post
    Are you selling the original seats that you've replaced?
    Greg
    Hi Greg,
    No I will be keeping the original seats.
    Mike
  2. #12
    Olde thread alert... but it's an interesting thread.
    Darth,
    Did to manage to fit your seats into your car?
    Does anyone know if Recaro ever made a purpose-built base for fitting Idealsitz S into a pre-'73 911? (It needed to be non-tilting and raked)
  3. #13
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Quote Originally Posted by blue72s View Post
    I can give you a definitive undefined answer.
    They listed their Brackets even in later catalogs only as until 68.
    However they show an Idealsitz S in a LWB Targa
    However you can mount the seat on the early tilting base and you can use the Brackets used for GRP buckets also.
  4. #14
    The IdealsitzS does not need any tilting mechanism. I have seen some Recaro non-tilting brackets but they are not raked unfortunately.
  5. #15
    Jan 2011
    Horb a.N. Germany
    I know I have some of them.
    Well Recaro offered a DYI bracket kit for 2 seater (non tiltable) (#11.56.19) and 4 seater (#11.22.09) so with some amount of flat 5x30 and round steel ø14 you're free to build any "original Recaro DIY Bracket" you'd like.
  6. #16
    Darth,
    I did. I originally used the tilting base as shown in a early post in this thread, but then changed them for something similar to these
    I then made a bracket to attach the original comfort seat, seatbelt brackets to.
  7. #17
    Quote Originally Posted by uai View Post
    flat 5x30
    Hi,
    Thanks. Are you sure it's 5mm thick?
  8. #18
    Jan 2011
    Horb a.N. Germany
    if you want something with a rake I'd just get these
    https://www.zuffenhaus.us/product/rs...t-seat-mounts/
  9. #19
    Name:  seat rail question.jpg
    Does anyone know the Recaro part number for item #2 in the left image? (zoom in if you can)
  10. #20
    Jan 2011
    Horb a.N. Germany
    These were introduced later - They didn't exist back then when the Idealsitz S was still in production.
    I have some of these somewhere. But they are part of other Brackets so I don't know if they have a part# on them.
    IIRC they were part of some Opel Brackets
