Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: WTB: Hi and low trumpet horns for 1973 911
    Jun 2012
    London, Ontario, Canada
    Looking for good shape (at least 8.5/10) red horns for my '73 S. It is a Feb '73 car and must have trumpets. Not the crappy GM horn that was on her. Must be like those in picture. If you have non-working ones that I could fix, we can talk.
    thanks
    Ravi
    Early 911S Registry # 2395
    You might give some consideration to purchasing the replacement hi/low trumpets from PORSCHE which come black, but very simple to remove the top covers and repaint...did it on my 73 and I thought it looked as perfect as one would need. Same original sound.
    Jun 2012
    Thanks. I did see a DIY on the bird and have contemplated it as a cheap option. http://forums.pelicanparts.com/porsc...arly-911s.html
    Certainly will do in a pinch until I can find some real ones. I don't want to cut corners on this restoration. The few items that are reproductions or new OEM are placeholders for when I find "the good stuff". Except for Soterik's wiper arms, which will stay with the car forever.
    Ravi
    Ravi,try Retro Automotive Products in Claremont,NH 866 737-1733.I bought a pair from them a while back 9.5 out of 10.
    Give them a call.
    Jun 2012
    Thanks for the lead David.
    Jun 2012
    Or just a Hi trumpet.???? I have a line on a Low one that looks good.
    Ravi
    Ravi
    I found some some non working trumpets where both the tubes were in decent shape and swapped the tubes to the new, still available, black horns and I now have 2 perfect working units. It is usually only the head part of these that cracks like crazy.
    It saves all the hassle of trying to repaint black tubes to red
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Jun 2012
    Certainly under consideration as a temporary measure. 5 minute fix and easier than painting. Ultimately though, still want originals. No shortcuts for this car.
    Ravi
    We've bought new horns, took them apart, stuffed them and shot with plastic paint. I couldn't have been more pleased with color and finish. G.Led
    Jun 2012
    Clarify stuffed them ? If I can't find an original, I'll probably do this as a temp fix, but just so people are clear,
    I'm looking for a Hi horn still. Low in great condition found.
