Results 1 to 10 of 10
Thread: FS: Early 911 Hickok Seat Belt Latch Pivot Pin & Bolt
    These kits replace the seat belt latch pivot bolt that must be destroyed in order to re-chrome Hickok (American Safety Equipment) latches.
    Material: Titanium, Gr 5 (6AL-4V)
    Finish: Shaft: Ra 12µm (As machined), Head: Ra .2µm (Mirror polished)
    Weight: 8.12 grams (versus OEM 14.30 grams)
    The price is $27.18 per kit, consisting of one bolt & pin.
    USPS flat rate shipping in the US is $7.90
    Oct 2011
    California
    PM sent to Jimmy.
    Jun 2015
    I would like to purchase two of these kits.
    How about making adjusters? They go bad or missing a lot.
    Hi Painteddash,
    I don't believe that you are able to send or receive PM 's until you have 10 posts. If you would like to make contact, please post your e-mail so that I can contact you.
    Hi Rick,
    I sent you an e-mail.
    Thanks, Jimmy
    Quote Originally Posted by Painteddash View Post
    Mar 2024
    Hi Jimmy, I'm just seeing this - do you still make and sell those kits? Thanks, Tobias
    Yes. Because you have less than 10 posts, you can't send or receive PMs, so if you wish to purchase some pins, please post your e-mail address so that I can contact you.
    Quote Originally Posted by tas_de912 View Post
    Mar 2024
    Quote Originally Posted by JimmyT View Post
    Brilliant! I'm at p912tas@gmx.net - Thanks!
    Mar 2024
    Hi guys,
    sharing this, hoping it might be helpful to some of you in sourcing pin kits when restoring the Hickok seat belts.
    Apparently there is (at least) two Hickock buckles:
    the ASE 11-101 (round decal), using a riveted design, to those JimmyT is selling kits
    the PG 12171-1 (heraldic decal), using a c-clip, which can be removed and replaced
    Now, my car came with the latter, and the previous owner – not finding a solution to replace the pin – rechromed the buckle as a whole. That at the end resulted in a) the springs inside getting corroded by the chemical dip, losing tension and finally snapping off and b) the c-clip being backed to the buckle housing.
    What I find in endless nighttime Google sessions is, that there is a repro seat belt that Wolfsburg West ist selling for classic Beetles, Busses and Karman Ghias – using the exact Hickock PG 12171-1 patent. Reasonable priced too, so I ordered a pair of those – grinded off the c-clip on the old ones, and voilá, was able to get everything together back again as new with the spare pin and spring from the repro seat belt. Still need to rechrome the parts, but at least now it can be done the right way. I'm sure you can reproduce the pin yourself using a bolt, forking and notching it - but that was the most efficient way I found.
    Best.t
    My reply to a post I saw on 912 BBS today
    Quote Originally Posted by tas_de912, post: 497176, member: 11334
    Hi guys,
    • the ASE 11-101 (round decal), using a riveted design, to those JimmyT is selling kits
    • the PG 12171-1 (heraldic decal), using a c-clip, which can be removed and replaced
    Best.t
    (My Reply):
    ASE 11-101 HICKOK SEAT BELT REPLACEMENT PERMANENT PINS CAN BE PURCHASED FROM:
    (Outstanding Reproduction Pin’s) “Solved my problem!”
*(Otherwise one has to reproduce them using a machinist)
Jim Tidwell at:
    (You have to email him for a request)
    Email: jim@tidwell.org
Another solution would be to drill the original pin and use a “Roll Pin” in the drilled hole to lock i*in.
Here is a video showing precisely how to do that from Mike’s Restoration, who painstakingly restored his unbelievable 1967 Porsche 911S to perfection! His early 911 Hickok Seat Belt Restoration and “Roll Pin” Safety Pin “fix” was an amazing alternative solution!:
His AMAZING 911 has got to be one of the most beautiful 1967 911S’s in the world. Incredibly talented individual! It is well worth your time! Trust me…
    Mike’s Seat Belt Restoration Video:
    https://youtu.be/gdCldLjnuXU
Check out his many other videos…You will not be disappointed: The Early 911 community should watch every one of his outstanding videos
    https://youtube.com/@MikesRestorations
I hope this helps…
I restored my own Early 911 Hickok Seat Belts using Mike and his detailed videos as my inspiration!
Note:
    The Porsche Crest Reproduction Replacement metal buckle sticker can be found at AASE SALES who is a great source for all kinds of Porsche parts:
    https://www.aasesales.com/
    LINK:
    https://www.912bbs.org/forum/threads...-2#post-497176
