Results 51 to 59 of 59
Thread: FS: Bill Harris; 911R Replica
Threaded View
    Hello,
    My name is Jill Harris and I am the wife of the late Bill Harris. I am selling his 911R built car. Below are detail and pictures of the car. Please email me with interest in the car. jbkharri@msn.com
    Asking Price: $70,000
    Body
    Grand Prix white with tangerine stripe; All painted in Acrylic Urethane single stage
    Black 911R vinyl scripts
    Bare metal strip to exterior tub
    New floor pans and suspension pan installed by PO
    911R steel flare custom formed and butt welded
    RSR type hood with balsa and amber liner
    911R front fender with bucket custom to Werks spec
    911R front bumper to Werks spec
    911R rear bumper to Werks spec
    911R rear deck lid with amber liner
    Steel early doors converted to 911R interior spec
    911R plastic door handles
    911R rear tail lights with lights
    911R engine lid grill
    Rear lid hold downs
    Hood hold downs
    911R stainless lid hinges
    911R acrylic vented ¼ window with trays
    911R Acrylic door vent windows with spin vent
    Acrylic door windows with leather pulls straps
    Leather door stops
    911R front turn signal / side marker lights
    911R Bi iodine headlights
    New front /rear windshield rubbers
    New door/ hood/ body 2 bumper seals
    Large round durant mirror
    Chassis stiffing engine compartment shock towers
    Chassis stiffing at torque tube
    Interior
    911 R style race seats with basket weave inserts
    Werks type roll bar
    Perlon carpet kit
    Dead pedal
    New German vinyl off white headliner
    Early dome light
    5 point harness
    Chrome SWB rear view mirror
    Momo period correct steering wheel
    Clock delete
    Radio delete
    Drive Train
    Engine
    Core starting motor 1982 large port long block
    Static / dynamic balanced/ new bearings/ chains/ ring/ gaskets
    Build install motor
    3.0 crankshaft STD/STD polished
    Rods resized/ rebushed/ balanced/ ARP rod bolts
    J&E pistons 10.5 : to 1 pistons/ rings/ wrist pins
    3 angle grind valve job
    Regrind 4 journal cam shaft to S Spec Web Cam
    40mm Weber carburetors rejected to 3.0 S spec tall PMO manifolds
    908 style rain shield with tall air horns
    RSR amber shroud and tins
    3.0 recurved distributor
    Bosch unshielded spark plug wire set
    Pulstar Platinum spark plugs
    MSD 6AL ignition and coil
    1 5/8 RSR style headers
    Biscoff muffler converted to Werks rally spec with baffles
    KEP 215 mm performance flywheel / clutch pack
    RSR motor mount
    3.2 Alternator/ fan
    3.2 starter
    993 oil filter console ( replaced engine oil cooler
    Transmission
    1967 aluminum 901 5 speed
    MSX gears
    Nice dogs New Scyros hubs
    1900
    Oil System
    1972 911 oil tank
    External 80mm filler neck
    Aluminum 80mm filler cap1972 911 S oil filter housing
    1988 Carrera front oil lines and fender cooler
    Coline oil lines custom fitted
    911R overflow tank ( SWB washer bottle)
    993 2nd oil filter housing (replaces engine oil cooler
    Fuel System
    100 ltr Rally type fuel tank with 100mm though hood filler neck
    Holley Red fuel pump
    Holley fuel pressure regulator and gauge
    Suspension
    1988 Carrera front suspension
    Boge 3.5” struts painted orange
    964 4- piston calipers
    Stock Carrera front torsion bars
    RSR type front sway bar 15mm
    964 4 -piston rear calipers
    Boge rear shocks painted orange
    Carrera rear adjustable spring plates modified for SWB
    Stock Carrera rear torsion bars
    RSR style rear sway bar 19mm
    Dual master cylinder pedal assembly
    Tilton masters 5/8 rear ¾ front
    15X 6 Deep six wheels polished and shadow painted
    195front tires 205 rear tires
    80mm wheel studs
    Open steel lug nuts
    RSR front strut brace
