Page 13 of 15 FirstFirst ... 31112131415 LastLast
Results 121 to 130 of 143
Thread: PCA Parade, 2014 . . .
  1. #121
    More Parade, 2014 . . .
    More 917/10K . . .
    Not conventionally pretty . . . more like menacing --- frightening, almost. Definitely other-worldly
    Visually similar to the subsequent /30 . . . missing only the longer rear body-work, the inter-coolers housed there --- the /10K has none . . .
    . . . and, oh . . . about 600 HP
    Yiiiiiiiikes!
    1 of 12?
    917K . . .
    Always surprised by how small these car are, in person --- 36.something inches tall?
    More 917K . . .
    4.5 liter, 520 HP, 800 kg/1775 lb
    zero-to-60 = 2.7 sec, zero-to-100 = 5.5 sec
    . . . and this is the lowest-spec version
    Interesting detail = check-out the rear-view (mirror) = '. . . 1st rule of Italian driving . . .'?
    906 . . .
    . . . bka Carrera 6
    F Piëch's first 'clean sheet' project. Tube-framed w/ just a kiss of fiberglass = 580 kg/1300 lbs
    I own furniture that weighs more
    Not fragile; one o' these won the Targa overall in '66
    Also --- Porsche's last street-legal (gulp!) race car
    1 of 50
    American Racing, huh? Snazzy . . . but better suited/fitted 'cause the Old Skool steel-cum-alu GT wheels cost the Earth . . . or have long-since disappeared from
    904 GTS . . .
    Moving away from all-metal cars + racer 1st/street car maybe
    Steel chassis w/fiberglass body (chopped + sprayed) bonded to
    630-680 kg/1400-1500 lbs, 200 hp, 160 MpH
    1 of 106?
    2x exh = 6x cyl?
    The office
  7. #127
    906 was not clean sheet. Ferry mandated it use the spare 904 suspension parts (much to Piech's dismay) they had ordered already, thinking it would have a longer lifetime than Piech would give it. 906/10 was the first clean sheet in that it used a new suspension, based on an F1 Lotus (hence the 13" wheels). They did actually use spare Lotus uprights on the first hillclimb car. I am going to butcher the name but I think it was Oillon-Villars.
    That is the first time I have ever heard that the 917 frame was permanently pressurized. There were certain tubes carrying oil that would be pressurized, but as far as I know the rest of the tubes were only pressurized after the race to check for cracks, although mostly they just built new chassis for each race anyway so why worry about it? A pressure gage on a race car frame is more likely to cause a crack from its mass vibrating on a welded bung. And really, they would never pull a car out of the lead for a tiny crack that could cause a pressure drop but not affect the structural integrity much at all.
  8. #128
    The Grandson's Car
    Quote Originally Posted by Flieger View Post
    . . . 906 was not clean sheet. Ferry mandated it use the spare 904 suspension parts . . .
    I suppose the same be said for the engine . . .
    . . . or the gauges . . .
    . . . seat upholstery
    Or the Uncle? --- who took Volkswagen power-trains + contraband aluminum to conjure-up cars in a saw mill
    904 bits, indeed --- and yet . . . look at the two
    A year apart --- generationally consecutive . . . . . . . . and cosmically different
    One --- still the Son's car . . . born 4-cam
    The Other? . . . . not
    911T/R . . .
    Another thread . . .
    http://www.early911sregistry.org/for...ly-is-a-911-TR
    More 911T/R . . .
