True. Don’t want to revisit this area anytime soon or maybe ever!
Bob - any more pictures of the Targa before you started restoration? We're reading the final chapter now, but love to see chapter 1.
OK.....
I will start with just asking to look at the car as i knew it had been parked in the back yard for 40 years.
As i dug it out of the bushes i saw that it was a 1968 911L Targa.
Spent a couple of days digging it out just for the pleasure of seeing it.
Out of the blue I was asked if i wanted it.
I said the only way it could possibly be saved is if it had a donner rear torsion bar clip.
It so happened that there was a wrecked but non rusty 1968 Attachment 599924911L coupe rear clip that could come with the car
So the first part of the project was to repair the rear piece.
The process I chose was to remove all spot welds on the rear wheelhouse (both sides) and remove the rear cross member
I would turn the car upside down and had a couple of steel plates cut so that I could mount the large plate on the transmission mounting points and elevate the other end back at the rear engine mounts such that it was on the Design Datum Plane at the transmissions elevation.
I then installed 3/4" turnbuckle stations .One at the rear engine mount and one at the shock tower.
With the spot welds removed it was easy to straighten the wheelhouse associated parts.
I installed the engine mounting hardware to keep the rear dimension in place.Attachment 599925
so now that I got the wheelhouse and associated parts straightened.
I carefully prepared and installed the torsion bar and wheelhouse areas using my Datum Plane Plate for reference and measurement.
Attachment 599927
Attachment 599933
Attachment 599934
then installed the rear crossmemberAttachment 599928
Attachment 599929
Attachment 599930
Attachment 599931
Attachment 599932
removed DatumPlate and epoxy primedAttachment 599935
Attachment 599936
Cleaned up and epoxy rear seatAttachment 599937 and partial bulkhead
installed rear seat area and rear parcel trayAttachment 599938
Attachment 599939
Attachment 599940
Attachment 599945
Mocked up the rear quarter panels and engine lid to assure correctness.Attachment 599941.
Attachment 599942
Attachment 599943
Attachment 599944
