final clear coat on front hood..
Attachment 572222
Attachment 572223
Attachment 572222
Attachment 572223
Restoration Design Key Fob
Painted in Light Ivory....Attachment 572244
Nice touch Bob ...
Final clear coat on driver and passenger door...
Attachment 572556
Very Tidy Job... Well done yourself!
final clear coat on the rear quarter panels
the rear cross member and door jambs...Attachment 575034
Attachment 575035
Attachment 575036
Attachment 575037
the driver door had some very small solvent pops.
at first i thought i was going to sand it down and re -clear.
I ended up wet sanding with soapy water and 800 grit on a knife sharpening stone that i used as a sanding block..
luckily it all sanded out .
so now it is "cut" and preliminarily "buffed"
looks fine...
Attachment 575157
This is really fun to watch
check this out ... the clear disk in the bottom of this 3m liner is PPG Deltron DC4010.
IT sat for a couple of weeks and the bottom of the 3m liner measures 90mm, the disk has SHRUNK to 80mm.
Wow, back in the 70's and Attachment 57547580's I knew my product very well.
On this project I have been at the mercy of the local paint jobber.
More than a 10% shrinkage is outrageous.
Back on the gun..........
Passenger fender final clearcoat.Attachment 577188
Attachment 577190
Attachment 577192
